1997 Pontiac Grand Am replace 97 grand am engine with a 94
1997 PONTIAC GRAND AM
170,000 MILES • 6 CYL • FWD • AUTOMATIC
FREETHUNK
I have a 97 grand am gt that threw a rod through the front of the engine. I'm looking at buying a 94 grand am to replace the the one in the 97. If I remember correctly, I read somewhere that the engines in these two years are compatible. I was hoping someone could enlighten me on whther or not this is true. Thank you in advance.
Sep 17, 2010 at 4:26 PM
ERNEST CLARK
  • 1,730 POSTS
As long as the engines are exactly the same, it will interchange. However, you'll have to check on your state laws to see if this is allowable.
Some states won't let you replace a newer engine with an older one. You'll fail an emissions inspection.
Sep 25, 2010 at 6:08 PM
