When I drive the car the powersteering is leaking from behind the mastercylinder where it connects to the booster. In the garage I wiped it all down and turned the wheel back and fourth and I saw the fluid coming out from below the mastercylinder where it bolts up. There is only one hose that connects to the booster and I replaced the check valve that the hose connects to. It is not brake fluid, that level does not go down, but the powersteering looses fluid and gets alot of air in it. It seemed to help some when I loosened the powersteering cap and drove it but I know this is not a real solution to the problem. Is my Booster bad? Or is it the Rack or something else????
Jul 26, 2010 at 11:08 AM
