1997 Pontiac Grand Am No codes from computer
1997 PONTIAC GRAND AM
169,000 MILES • 6 CYL • FWD • AUTOMATIC
TIM BURNS
I have a 97 Grand Am that started surging and died 40 miles into road trip. On the way home I stopped to have the codes read and the reader did not get power from the car when plugged in. Check engine light comes on and flashes multiple codes, gas mileage tanked on the drive home. Any ideas?
Jan 5, 2008 at 7:34 AM
MERLIN2021
  • 17,250 POSTS
The only thing you can do is check the fuses for PCM, in the power distribution center under the hood, Follow your positive battery cable to it..
Jan 5, 2008 at 9:37 AM
TIM BURNS
I checked the fuses, all looked good. Thanks anyway.
Jan 5, 2008 at 11:55 AM
MERLIN2021
  • 17,250 POSTS
Also apparently GM has had trouble with connectors not being put together too well, check connectors, especially the one with the metal clip...
Jan 6, 2008 at 8:50 AM
