I have looked at the schematics 3 times throughout the night, so I could be 90% sure before I responded.
I don't see anything that could cause it other than a bad processor in the instrument cluster.
If you're feeling really lucky, you could unplug and then replug in the connectors a few times over an over again to make sure you have a good clean connection.
And do the same with the 10 amp fuse for the instruments in the fuse box.
But I really think it's in the cluster.
Good luck
SPONSORED LINKS
Wednesday, December 17th, 2008 AT 2:00 AM
