1997 Pontiac Grand Am fusible links
115,000 MILES • 4 CYL • FWD • AUTOMATIC
DAN LASHER
I have just installed a new alternator on my car(which was tested before I brought it home it tested good) the problem is that the fusible links keep burning up, also the wire gets very hot to the alternator, (the large wire.) THe alternator is putting out aprox 13.5 volts if I skip the fuse but I can not do that for safety reasons.
Jun 9, 2009 at 1:43 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_186.jpg
As you see in the diagram its a straight shot from the starter solenoid do not take this the wrong way but the most common I ve seen and admit that I did it once or twice is over torque the nut and the wire causing the insulator to brake and ground the terminal you may check that Ohm check the red wire, check around the exhaust system for a melted wire good luck and let me know
Jun 9, 2009 at 11:02 PM
BMRFIXIT
  • 19,053 POSTS
After you ran a wire was it the fuse that burn or the fusible link
let me know
Jun 10, 2009 at 10:27 AM
DAN LASHER
Jack thanks for your help. actually I replaced the link and it burnt up,then I wired in a 40 amp fuse and it poped that too. Ive done electrical work for years an this one has me confused.
Jun 11, 2009 at 5:21 AM
BMRFIXIT
  • 19,053 POSTS
We still talking about the red wire rear of alternator
you ran a new wire from the battery to the alternator with a 40 A fuse and the fuse burnt than I would suspect bad alternator
let me know
Jun 11, 2009 at 10:21 AM
DAN LASHER
yes it is the big red wire to thealt and the battery
Jun 12, 2009 at 9:01 AM
BMRFIXIT
  • 19,053 POSTS
Hi Dan
was the alternator changed ?
let me know
Jun 12, 2009 at 10:47 AM
DAN LASHER
yes i bought a rebuilt alt - but I had them test it before I left the Store it checked good Thanks for your help! also it does put out 13.5 volts . but burns up the fusible link
Jun 15, 2009 at 8:13 AM
BMRFIXIT
  • 19,053 POSTS
Alternator is new and you ran a new wire and fused it and keep on burning the fuse
you have an over load, at this point I would retest the battery and or try another one
let me know
Jun 15, 2009 at 9:43 AM
