1997 Pontiac Grand Am Alternator
GUAMKID
Engine Mechanical problem
1997 Pontiac Grand Am 4 cyl Two Wheel Drive Manual
how do i replace the alternator
Mar 16, 2010 at 11:10 AM
  • 75,988 POSTS
Alternator removal:
https://images.2carpros.com/forum/automotive_pictures/12900_alty_67.jpg
REMOVE OR DISCONNECT Negative battery cable at battery. Serpentine belt. CAUTION: To avoid personal Injury when rotating the serpentine belt tensioned on 2.4L use a tight fulfilling 13 mm wrench that Is at least 61 cm (24") long. This operation can be done using tool J 37059 or equivalent. Generator mounting stud and bolts. Generator electrical connections. Generator assembly. INSTALL OR CONNECT Generator assembly. Generator electrical connections. Generator mounting stud and bolts. Serpentine belt. Negative battery cable. Hafa adai to do mauleg
Mar 16, 2010 at 11:27 AM
