Where do my starter sit on my 96 grand am gt
, and what tools do I need for the job?
Thursday, September 30th, 2010 AT 6:46 PM
BLUELIGHTNIN6
MECHANIC
The starter is located under the intake manifold. The first thing you need to do is disconnect the battery. The bolts on the starter are 15mm. You need to jack the car up or get it on a hoist to get one of the bolts out. The other bolt is a lil harder to get at but you dont need the car in the air to get at it. It makes it easier to get at if you remove the A/C compressor. You will need about a two foot long extention to get to the bolt. I advise spraying penetrating oil on the bolts and letting it sit for about 15 min. You will have to try and slide the starter out the bottom. It will make it easier if you take off the oil filter before you try to slide it out. So basically you can do two jobs at once. Change the starter and the oil
