1996 Pontiac Grand Am Trouble Code
153,000 MILES • 4 CYL • FWD • AUTOMATIC
LOGSHERIFF
I have a 1996 Pontiac Grand AM SE with a 2.4 the computer is giving me a Code "P0304" the plug boots are new and I have tried replacing the coil pack for the #4 cylender and the computer still gives me the same code. What should I look at next?
Dec 5, 2009 at 2:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
let me know if you need further diagnoistic steps.. (steps 1 & 2 not needed)
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1233.jpg
Dec 5, 2009 at 2:25 PM
LOGSHERIFF
This engin is a newly rebuilt motor with new gaskets and hoses as well as new plug wires and boots so all of the sugested trouble shooting tips you mentioned are taken care of. I even tried replacing the coil pack that runs the number 4 cylender. There seem to be no vacume issues or visual spark issues with this motor because everything is new with the exception of the ignition module itself. Could it be the ignition module???
Dec 5, 2009 at 11:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
ok if the basics have been covered then and since it is newly rebuilt the cylinder should have good compression. it really only leaves the ignition control module or the powertrain control module.
Dec 6, 2009 at 5:39 AM
