1996 Pontiac Grand Am smell of strong gas
MAHAL69
  • 1996 PONTIAC GRAND AM
Smells problem
1996 Pontiac Grand Am 6 cyl Two Wheel Drive Automatic
only when it put gas once it is on e and on a hot day and the smell comes though the air conditinor when its on and can be smelled long time after the car is off from out side by engine and cab, but there is no leak underneathe, what could it be?
Sunday, June 29th, 2008 AT 4:56 AM
BMRFIXIT
  • 19,053 POSTS
You have a leak and you have to check
it may not be big for it to drip at the ground
check under the hood fuel lines and injectors
you need to have it checked
Risk of fire.
"Â Keep cigarettes, sparks, open flame, and other
sources of ignition away from vehicle.
"Â Gasoline, methanol, and oxygenated fuels are toxic
and flammable and must be handled appropriately
Have an automotive repair question!
Sign up and ask your automotive question !
Sunday, June 29th, 2008 AT 5:52 AM
