1996 Pontiac Grand Am oil pressure sensor
1996 PONTIAC GRAND AM
178,000 MILES • 6 CYL • FWD • AUTOMATIC
96JAMES
I 'va had alot of trouble with keeping my car running. Checked fuel pump and relay. Ignition module and ignition switch. Bad connection on main fuse panel under hood. Relpaced with new wire a proper fuses. Still car will run for about 15 min and shut off. Narrowed down to oil pressure sensor where would it be located on a 3.1 eng.?
Dec 10, 2009 at 9:21 AM
Fuel Pump Switch/Oil Pressure Sender Right front of engine-sorry no pic
Dec 10, 2009 at 9:37 AM
96JAMES
would this going bad kill power to the fuel pump?
Dec 10, 2009 at 10:18 AM
It will it, It powers the F/Pump after it fires up.
Dec 10, 2009 at 6:11 PM
