1996 Pontiac Grand Am My Interior overhead light is stuck o
1996 PONTIAC GRAND AM
JENZPONTIAC
Electrical problem
1996 Pontiac Grand Am 4 cyl Front Wheel Drive Manual 143 K miles
I can seem to get it to turn off! My overhead light (no switch on it) Is stuck on. My boyfriend super glued the locks and it is not a sensor - per the pontiac dealership, may be the wires?. Sooo long story short - i have to remove a fuse if i do not want my battery dead. Any suggestions (pleaseeee!!!)
Thank you!
Jenn
Mar 13, 2008 at 11:31 AM
DONSTANG
One of the door ajar switches on your latch has probably gone bad. I do not know where your friend put super glue but if he did not put it in the latch and block it off, sometimes you can just spray wd-40 in the latch and it will fix the problem by freeing up the contact in the switch but if there is glue in there now you will probably be replacing the latch.
Apr 8, 2008 at 11:48 PM
