1996 Pontiac Grand Am Makes whining noises when turning and
1996 PONTIAC GRAND AM
18,100 MILES • 6 CYL • FWD • AUTOMATIC
JPRICE123
please help,I checked power steering fluid and it was empty filled it up and something smells like it is burning.car makes whining sounds when i turn and when i accelerate going straight..any help would be appreciated...thanks james
Feb 22, 2009 at 5:24 AM
MMPRINCE4000
  • 8,548 POSTS
Check the pressure and return lines for leaks, make sure the PS tank is full, if whining continues, the pump would need to be replaced and any leaks fixed.
You may try a PS additive that stops PS pump noise first, see if it helps, but most likely the seals/bearings are gone.
Feb 23, 2009 at 12:18 AM
