1996 Pontiac Grand Am location of oil pressure sensor
96JAMES
Engine Performance problem
1996 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
you told me yesterday that it was on the right front?
Is it located behind the cover that the water pump bolts to? Took of the p/s pump found cam sensor in that area?
Dec 12, 2009 at 9:20 AM
  • 75,988 POSTS
What are you looking for I gave you for the oil pressure switch not for the camshaft position sensor-
Dec 12, 2009 at 9:27 AM
