1996 Pontiac Grand Am ignition lock cylinder replacement
15,600 MILES • 4 CYL • FWD • AUTOMATIC
MULEDEER1960
I need to know the steps required to replace the lock cylinder. The key has been giving me trouble since I purchased the car in 02,now it quit completely.Removed the electrical switch from the back of the cylinder and car will start with screw driver,but stalls,anti theft device kicks in,need to replace cylinder,but not sure where to start. Thanks for any info
Jul 21, 2008 at 3:47 PM
MERLIN2021
  • 17,250 POSTS
IGNITION SWITCH Removal & Installation Disable air bag system. Disconnect negative battery cable. Remove steering wheel. .Remove upper and lower column covers. Place shift lever in Park. Turn lock cylinder to OFF-LOCK position. Disconnect ignition switch electrical connector. Remove ignition switch.
https://images.2carpros.com/forum/automotive_pictures/62217_Locka_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Lockb_1.jpg
Jul 31, 2019 at 9:51 AM
MULEDEER1960
So what is the correct way to turn off this system? I,m just a farmer with spare time,no airbags on tractors,,lol
MERLIN2021
  • 17,250 POSTS
Just remove the negative(-) battery cable, and wait 2-3 minutes...
