1996 Pontiac Grand Am gas pump problem
99,000 MILES • 4 CYL • FWD • AUTOMATIC
DIAZ101
how would you know if your gas pump is not working?
Nov 30, 2008 at 11:20 PM
MMPRINCE4000
  • 8,548 POSTS
If you mean fuel pump, the engine would not start. On some cars you can hear the pump energize when you turn the key to "on" for a few seconds, then a "click" which is the relay and then pump would turn off untill you start the engine.
The only real way to be sure is to have the fuel pressure tested with a mechanical gauge. If no pressure, then pump, fuse, relay or wiring.
Dec 1, 2008 at 12:26 AM
