1996 Pontiac Grand Am fuel filter replacement
130,000 MILES • 4 CYL • FWD • AUTOMATIC
PONTIAC_PROBLEMS
I am needing some information on how to replace my fuel filter including the tools it takes to fix it, and how do i release the gas pressure before removing the filter. i have try to loosen it but the bolt is way too tight i was wondering if there is a special or specific tool that will help to get it to come off easier.
Aug 23, 2009 at 9:35 AM
MMPRINCE4000
  • 8,548 POSTS
One side is double inverted flare, use tubing wrench and hold down wrench. Other end, simply press plastic tabs together and pull off.
Aug 24, 2009 at 12:14 AM
