1996 Pontiac Grand Am EVAP & EGR Monitors
17,000 MILES • 6 CYL • FWD • AUTOMATIC
LATENIGHTROME
I FINALLY figured out that a clogged passage port to the egr valve, and a disconnected evap service line was the the cause of 2 trouble codes I was getting. Fixed that! Cleared the codes, and drove the car for a few days. Evap & egr monitors never set to ready. First mistake, I disconnected the negative cable from the battery. Drove for 2 weeks (highways & streets), and still Not Ready.
Car runs, and sounds a lot better than when the egr passage was still clogged. Tried this drive cycle I found online, but still didn't work. Any ideas welcomed, and thanks in advance!
Apr 25, 2009 at 1:13 AM
KHLOW2008
  • 41,812 POSTS
Hi LateNightRome, GM does not provide any specific procedure for driveability relearn and I hope the attached info helps.
https://images.2carpros.com/forum/automotive_pictures/192750_RelearnPCMGM_1.jpg
Apr 28, 2009 at 6:29 AM
