Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Grand Am
Emission
EGR Valve
Replace/Remove
1996 Pontiac Grand Am EGR Valve
1996 PONTIAC GRAND AM
219,000 MILES • 6 CYL • FWD • AUTOMATIC
JODYL30
MEMBER
1 POST
In order to pass emissions after replacing the ERG valve, do you have to drive for a 100 miles to reset the computer?
Feb 12, 2010 at 12:11 PM
MMPRINCE4000
Experienced Mechanic
After replacing the EGR, use a code scanner to reset the error code.
Code should not re-appear, if it does, reset, if it comes on again, then EGR control system or possible PCM problem.
EGR meters exhaust gasses back into intake to prevent the formation of oxides of nitrogen (NOX).
If valve was not opening, the combustion temps increase, if it was stuck open, engine would hesitate, stumble, possibly not start.
Feb 13, 2010 at 12:19 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
