1996 Pontiac Grand Am EGR valve
1996 PONTIAC GRAND AM
126,000 MILES • 4 CYL • FWD • AUTOMATIC
ASLATER4
how go you change a EGR valve on a 1996 Pontiac Grand Am Se 4cyl
Feb 23, 2010 at 9:18 AM
EGR Valve
https://images.2carpros.com/forum/automotive_pictures/12900_egr_3.gif
REMOVE OR DISCONNECT 1.Remove the Air Cleaner Outlet Resonator. 2.Disconnect the electrical connector to the EGR valve. 3.Remove the EGR valve bolts (1). 4.Remove the EGR valve (2). INSTALL OR CONNECT NOTE : Be sure all gasket material is removed from the EGR mounting surface. Even a small amount of material may cause a DTC P0401 to set. 1.Install the EGR valve (2) with the gasket (3). 2.Install the EGR valve bolts (1). *Tighten the EGR valve bolts to 22-30 Nm (16-22 lb. ft.) . 3.Connect the EGR valve electrical connector. 4.Install the Air Cleaner Outlet Resonator.
Feb 23, 2010 at 9:24 AM
