1996 Pontiac Grand Am EGR Valve
219,000 MILES • 6 CYL • FWD • AUTOMATIC
JODYL30
In order to pass emissions after replacing the ERG valve, do you have to drive for a 100 miles to reset the computer?
Feb 12, 2010 at 12:11 PM
MMPRINCE4000
  • 8,548 POSTS
After replacing the EGR, use a code scanner to reset the error code.
Code should not re-appear, if it does, reset, if it comes on again, then EGR control system or possible PCM problem.
EGR meters exhaust gasses back into intake to prevent the formation of oxides of nitrogen (NOX).
If valve was not opening, the combustion temps increase, if it was stuck open, engine would hesitate, stumble, possibly not start.
Feb 13, 2010 at 12:19 AM
