1996 Pontiac Grand Am dragging right front brake
165,000 MILES • 6 CYL • FWD • AUTOMATIC
SNUFFAD
I noticed my right front brake was dragging on the way home. When I got home the right front brake and wheel rim was indeed hot and smelled. So being I have the time, I put new dust boots on all four wheels and new piston seals on the front brakes. I cleaned out alot of muddy looking stuff in the calipers and wheel cylinders in the back. I figured the dirt was interfering with the piston returning to its state of rest. But, the problem still exists. I bled the brakes alot to remove all the old brake fluid. I kept everything clean and went buy the book. I also cleaned all the brake surfaces when done. The crome plating on the piston in the front brakes is in excelent condition. The car actually drove fine the first time I drove it but, the second time the right front brake was dragging again. The brakes work smooth and there is alot of brake pad thickness. I have not beed the system at the ABS modulater bleeders cause, I never let the amount of brke fluid go too low. Whats going on?
May 22, 2009 at 1:31 PM
MERLIN2021
  • 17,250 POSTS
It's either a flex hose on the way out, or when you rebuilt the caliper, you put the seal in backwards, low drag calipers have a special cut on the inner edge of the seal to retract piston more...try the hose first, then flip the seal.
May 22, 2009 at 10:45 PM
MIKE28HONDA
i just replaced my calipers but still had the same problem.when bleeding the right front only a small amount of fluid came out,so i unhooked the line from the caliper and same thing,unhooked the rubber line from metal brake line and got all kinds of fluid.wish i would thought to check that first and saved some money.
May 29, 2009 at 11:44 AM
MERLIN2021
  • 17,250 POSTS
I did say try the hose first!
May 30, 2009 at 12:01 AM
