HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Engine Cooling
Coolant Temperature Sensor
1996 Pontiac Grand Am cooling system heat sensors
W. DENNIS LEATHERWOOD
MEMBER
1996 PONTIAC GRAND AM
Engine problem
1996 Pontiac Grand Am Front Wheel Drive Automatic 145000 miles
where are they located?
Friday, January 11th, 2008 AT 2:11 PM
BMRFIXIT
MECHANIC
Is it the coolant sensor you r looking for?
Also engine size will help 4 cyl or v6
let me know
SPONSORED LINKS
Friday, January 11th, 2008 AT 8:16 PM
Please
login
or
register
to post a reply.
Related Coolant Temperature Sensor Content
Would A Bad Engine Coolant Temperature Sensor Cause Acceleration Stumble Whenm Engine Is At Operating Temperature.
Asked by
drtcrzy
1 ANSWER
1996
PONTIAC GRAND AM
VIDEO
Coolant Temperature Sender Replacement
Instructional repair video
GUIDE
Coolant Temperature Sensor Symptoms
An automotive engine coolant temperature sensor, (ECT) sensor, or sometimes called a cylinder head temperature sensor is used to generate feedback information to the PCM...
Coolant Temperature Sensor Location
Hi, Where Is The Coolant Temperature Sensor Located On My Car Listed Above?
Asked by
Charles Cottrill
1 ANSWER
1 IMAGE
2001
PONTIAC GRAND AM
1998 Pontiac Grand Am Engine Coolant Temperature...
Engine Cooling Problem 1998 Pontiac Grand Am 6 Cyl Automatic 215000 Miles Car Starts When Engine Is Cold. Heats Up To 240-250 Degrees...
Asked by
alisiafawn
1998
PONTIAC GRAND AM
2001 Pontiac Grand Am My Fans Won't Turn On?
My Fans Won't Turn On And My Car Is Over Heating. Also Blowing Out A Lot Of Smoke. Just Has An Oil Change And Put Antifreeze In It. Would...
Asked by
missiann22
2001
PONTIAC GRAND AM
Why The Tempeture Get High?
If I Have Already Changed The Thermostat, Radiator Temperature Sensor, The Fans Work Well, And Recently Was Made An Overhall Because The...
Asked by
tony237
3 IMAGES
2002
PONTIAC GRAND AM
VIEW MORE
SPONSORED LINKS
Coolant Temperature Sensor Replacement
Online car repair manuals
