1996 Pontiac Grand Am Car does not accelerate
APDD_23
  • 1996 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 162,996 MILES
My car was runnung fine, and when I turned it back on and started driving I notice that my Speedometer was not marking, and the car was not accelerating which was making a ramming soundi
Wednesday, August 26th, 2009 AT 12:55 PM
MMPRINCE4000
  • 8,548 POSTS
Best place to start is to get the fuel presure tested with a mechanical gauge, if low (under 25psi) the car will idle, but pressure is not suffecient to run engine under load.
Also check the fuel pressure regulator vacuum line for presence of gas, which would indicate a ruptured diaphram.
The speedometer is a seperate issue, most likely a vehicle speed sensor.
Saturday, August 29th, 2009 AT 9:02 AM
Related Engine Low Power Content
