Been trying to get this thing to start. Ran with buster box to be moved to my house. Will start and quit. Fuel pump is working getting gas to injectors. Have changed map sensor. Ide speed sensor. Fuel filter. Still wont start. Have any other ideas what could be the problem. Car runs if u pour gas in throdle system
SPONSORED LINKS
Monday, July 27th, 2009 AT 6:17 PM
MMPRINCE4000
MECHANIC
If it runs by spraying starting fluid into the TB, then it is most likely a fuel problem. Even though you can hear the pump run, you should check fuel pressure with a mechanical gauge.
