1995 Pontiac Grand Am will not shift
MEHOLE
  • 1995 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 150,000 MILES
The transmission will shitf from park to reverse to nutral and to first but it will not shift above that, what I dont understand is that it worked fine a year ago when I first got it and it sit for a while now it wont work. The fluid is full. I have ran out of options and I dont have the money to take it to the shop!
Sunday, November 30th, 2008 AT 7:56 PM
MMPRINCE4000
  • 8,548 POSTS
Check the cable connection to the trans, make sure it is moving when the selector is moved.
Monday, December 1st, 2008 AT 8:29 AM
MEHOLE
Yes everything moves on the exterior of the trans and in the pan!
Monday, December 1st, 2008 AT 7:13 PM
MMPRINCE4000
  • 8,548 POSTS
If the selector cable is working properly, and is moving the selector arm on the trans. To all the gears P-R-N-D-2-1, and the fluid is full (always check with engine running, trans at temp. Car in Park)then you will have to get it inspected at a trans shop for a diagnosis. Some will do it for free, and use a local shop, not a chain.
Thursday, December 4th, 2008 AT 10:28 AM
