1995 Pontiac Grand Am Transmission leaks
KTOMPKINS01
Transmission problem
1995 Pontiac Grand Am Two Wheel Drive Automatic
The transmission is leaking after running or being driven, then after it cools, stops. It can sit in the driveway for week and never leak. Then we drive it and it leaks. we drive 15 miles to work one way. and in 3 days, the transmission is at the fill line again. Its leaking on the passenger front. Not sure if its a run-off leak or not, but that is where its leaking.
Mar 30, 2010 at 8:25 AM
MMPRINCE4000
  • 8,548 POSTS
Generally transmissions will leak at the axle seals, especially if original ones.
Mar 31, 2010 at 1:03 AM
