1995 Pontiac Grand Am Tie Rod Bolt
1995 PONTIAC GRAND AM
307,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIM8094
Hi This may not have anything to do with it but I just replaced either the tie rod bolt or the stabalizer bolt cause the old one must of fell off.
Problem is. After a left hand turn the steering wheel is turned to the left when I'm driving straight down the road. Then to the right after a right hand turn.
I dont hear anything but sense that something is slipping at a certain area when I'm turning the steering wheel.
Will this gradually get worse and how expensive?
Jun 17, 2008 at 8:21 AM
BLACKOP555
  • 10,386 POSTS
you have what is called "memory steer" and you should take it in and have an inspection and alignment performed.
could be a damaged steering knuckle.
Jun 17, 2008 at 3:23 PM
