Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
If above is OK, then have alignment checked.
SPONSORED LINKS
Friday, February 12th, 2010 AT 8:59 AM
