1995 Pontiac Grand Am motor mount
BICKERSRON
  • 8 POSTS
1995 Pontiac Grand Am 6 cyl
I have to remove a motor mount to put my new serpentine belt on is there anything I need to worry about when jacking the motor and removing the mount
Jun 26, 2009 at 9:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Just make sure any hoses / electrical connections that may be stretched are disconnected to prevent damage. Then slightly raise the engine, just enough to take weight off of the engine mounts. Remove the 2 bottom bolts on front engine mount. Remove the through bolt from the front mount and remove the mount. Should be able to remove belts then. Tighten egine mount bolts to 65 Ft Lbs when installing.
Jun 26, 2009 at 9:08 AM
