1995 Pontiac Grand Am help im freezing
73,000 MILES • 6 CYL • 2WD • AUTOMATIC
RGUTHRIDGE
vents only blow cold air when i turn fan on. also air comes out of all vents no matter what i select...
any help is appreciated...
thanks,
rick
Dec 9, 2009 at 3:02 PM
MMPRINCE4000
  • 8,548 POSTS
Start by checking coolant level, if OK, then warm up engine and quickly touch the heater core IN/OUT hoses, they should be both hot. If one is hot and one is warm/cold, then heater core is blocked.
Also check the heater control/divertor valve, the cable may be broke.
Dec 10, 2009 at 1:07 AM
