1995 Pontiac Grand Am engine temp and computer scan
144,000 MILES • 4 CYL • 2WD • AUTOMATIC
DON BARA
could you please tell me the normal running temp range of this engine. also,i am getting a comp. scan saying quad drivers 1...3...and 4 bad. also no speedometer reading(changed speed sensor already) thank you!
Feb 3, 2008 at 7:37 AM
SOURBERVILLE
The normal operating temperature of a 1995 Pontiac Grand Am is 180-200 F. It says it in the manual. Even though, mine over runs slightly over 200. But, if your temp gauge is the same as mine, it definitely shouldn't be on the right side.
Mar 13, 2008 at 9:53 AM
