1995 Pontiac Grand Am Coolant overflowing from reservoir.
1995 PONTIAC GRAND AM
135,000 MILES • 4 CYL • FWD • AUTOMATIC
WENDELL40
While checking coolant level I noticed that it was low. So I refilled it to acceptable level. Then I left the reservoir cap off and started the engine. Within just a few minutes, and with cap off, coolant began to build up in the reservoir and then started overflowing out of cap opening. My question(s) are this. Is this normal? Especially with cap off. The temp gauge showed very little temp. Is there maybe some kind of blockage? I saw no signs of coolant curculating in reservoir, just backing up. Thermostat, radiator, temp sending unit, gooseneck, and water pump are all new. By the way this is a quad 4, if that helps.
Aug 23, 2010 at 2:11 PM
  • 110,244 POSTS
If it starts blowing coolant out when the engine is cold, it sounds like a bad head gasket. Have that checked and let me know what you find.
Aug 23, 2010 at 4:20 PM
