1995 Pontiac Grand Am CAN I
JDELICATI
  • 1995 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 153,000 MILES
CAN I SWITCH OUT AN AUTOMATIC TRANSMISSION TO A MANUAL TRANSMISSION AND WHERE WOULD I FIND A MANUAL OR INSTRUCTION TO BE ABLE TO DO IT
Sunday, February 15th, 2009 AT 3:50 PM
MMPRINCE4000
  • 8,548 POSTS
While possible it is a lot of work. The car would have to have a manual trans. Available for that year. In other words, if a manual was not offered, it would be a gigantic job, requiring a lot of fabrication.
Manufacturers would generally have the body prepared for either, for example, a hole in firewall for the clutch MC, bolts or holes for the clutch pedal, brackets for clutch slave and on and on.
You can go to junkyard and inspect/take pictures/parts from a manual car and compare to yours, see what you need.
As far as I know, there is no manual or procedure published for this.
Wednesday, February 18th, 2009 AT 8:52 AM
