1995 Pontiac Grand Am Automatic door locks not responding o
230,000 MILES • 6 CYL • FWD • AUTOMATIC
IGOTRESPECT21
  • 6 POSTS
Hi there, I own a 1995 Pontiac Grand Am SE. I suddenly had a problem with the automatic door locks. They both worked that day and then all the sudden they stopped working. Neither door responds when you hit the button on the door and does not lock when put in to drive and does not unlock when the car is shut off. I was wondering what could cause this problem. I looked at the fuses and the one for the door locks is not blown. Any help is appreciated. Thank You.
Nov 3, 2009 at 5:14 AM
  • 110,248 POSTS
First, even though the fuse looks good, it could be bad. Check it for continunity or replace it. If that doesn't help, I need you to remove the door panel on the driver's side to see if there is power to the switch.
Let me know what you find.
Nov 4, 2009 at 1:26 PM
IGOTRESPECT21
  • 6 POSTS
i did replace the fuse and nothing happened at all.i have the door panel off now... what is it im exactly looking for?
Nov 4, 2009 at 8:39 PM
  • 110,248 POSTS
You need to check if there is 12 volts of power to the switch itself.
Nov 4, 2009 at 11:59 PM
IGOTRESPECT21
  • 6 POSTS
i actually saw that there were two fuses for the locks, one provides power to lock and the other to unlock, do both have to be changed in order to work?
Nov 5, 2009 at 12:12 AM
  • 110,248 POSTS
They both should be good.
Nov 5, 2009 at 12:18 AM
IGOTRESPECT21
  • 6 POSTS
what are the voltages supposed to come up at both the fuses?
Nov 5, 2009 at 12:23 AM
  • 110,248 POSTS
They should be at least 12+ volts.
Nov 5, 2009 at 2:45 AM
IGOTRESPECT21
  • 6 POSTS
ok, and the switch i should be testing is the connecter that is hooked up to the button, correct?
Nov 5, 2009 at 4:43 AM
  • 110,248 POSTS
Correct. The switch should receive 12 volts when the key is in the run position.
Nov 5, 2009 at 5:35 AM
IGOTRESPECT21
  • 6 POSTS
i tested both fuses and the fuses are good themselves.. but i tested the slot where the fuses actually go in and im not gettin any power to the lock one... im gettin full power in the other one but not the other... the switch was not getting power...
Nov 11, 2009 at 7:33 AM
