1994 Pontiac Grand Am rattling of car
VOLCANOBLAST
  • 1994 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 128,560 MILES
I would like to know whats going on with my car. When I'm on the freeway and start to go above 50 mph, the car starts to shake and it seems like the shaking is coming from the front passenger side. When I drove under 50mph you couldn't feel the shaking. I am beginning to hear the shaking when traveling around 30mph. What could be causing this?
Sunday, January 11th, 2009 AT 10:52 PM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad tire, or worn suspension part. First lift and support the offending corner of the vehicle and spin the tire, look for any "bubbles" or irregularities in the tire. If ok, see if there is any play in thewheel, brab top and bottom and wiggle, should be tight same for front to rear of tire. If you dont see anything obvious, have it looked at by a tech, the problem sounds like it is getting worse and could be dangerous
Monday, January 12th, 2009 AT 7:06 AM
