1994 Pontiac Grand Am Rattle in idle
1994 PONTIAC GRAND AM
KMSHAFFE
1994 Pontiac Grand Am 4 cyl 118000 miles
When starting car, there is a rattle on the underside that sounds to be coming from the front end. The rattle continues in idle and during low rpms, but ceases after accelerating. Turning the a/c on makes it sound much worse. I suspect either the catalytic converter or possibly the heat shield. Any ideas? Will it be possible to do the repairs myself?
Dec 11, 2008 at 1:14 PM
  • 110,244 POSTS
Hi:
Most likely it's the heat shield. Take a rubber mallot and tap on the exhaust system. If it's the shield, get a couple large band clamps and tighten them around it.
Dec 13, 2008 at 6:18 AM
