Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Grand Am
Ignition
Spark Plug
Replace/Remove
1994 Pontiac Grand Am problem with
1994 PONTIAC GRAND AM
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANWAR_NAT
MEMBER
1 POST
when i push the gas bedal the car start cuting off, some times it will hardly move. i have ghange the spark plugs but nothing change?
Sep 18, 2009 at 7:42 AM
MMPRINCE4000
Experienced Mechanic
Check the fuel pressure with mechanical gauge, if OK, then most likely the convertor is clogged.
Sep 19, 2009 at 1:12 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
