1994 Pontiac Grand Am piston ring problem?
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
DIXIEII2003
bought the car 3 weeks ago. had the oil changed a week later at a shop. noticed that when I checked the oil a week later, it was low so I added some, and again last week. Took it to the car shop and was told that the piston rings are defective, causing the oil to spray out. They recommend replacing the engine instead, which costs $1,600 and labor at $1,300.
Apr 27, 2010 at 8:20 AM
2CARPRO JACK
  • 11,533 POSTS
How much oil is it using exactly? Do you notice any blue smoke when starting or driving ? I take it there are no leaks that could cause the loss of oil.
Apr 27, 2010 at 3:04 PM
DIXIEII2003
We added 2 quarts of oil, then another 2 a week later. After the initial oil change, we noticed white smoke coming out of the exhaust. We were told that oil may have gotten into the manifold which causes the smoke. It disappeared the next day. No oil leak was noticed when leaving the car parked overnight. No smoke was seen either when driving the car but the driving is sometimes sluggish as if the transmission is slipping.
Apr 28, 2010 at 5:00 AM
2CARPRO JACK
  • 11,533 POSTS
Have a cylinder leak down test done, that will determine if the rings are bad in the engine, dont bother with a compression test if it is using oil
Apr 28, 2010 at 12:13 PM
