1994 Pontiac Grand Am overflow and steam
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
MILLER_MAN59105
i had just bought this car and granted i knew there were some problems but i was looking under the hood and what i think is coolant (green fluid) i could be wrong but it is leaking out and steaming what is this and how do i fix it? should i be worried
Apr 29, 2010 at 6:34 AM
MMPRINCE4000
  • 8,548 POSTS
Not a good sign, but check compression to rule out head gasket, then a cooling system pressure test to isolate leak (unless head gasket is bad, then DO NOT do a cooling system test).
May 1, 2010 at 2:18 AM
