1994 Pontiac Grand Am My brakwe lights are not working
1994 PONTIAC GRAND AM
156,600 MILES • 6 CYL • FWD • AUTOMATIC
BNOBLE22
My top break light will work but the two lower lamps will not work. The rear lamps come on when I turn the lights on. I checked the fuse it is ok. I have the brake light on the dash lit up. What could it be? Also my oil pressure is low I dont know if the gauge is bad because of the car is so old or its the pump. How can I check the pump?
Aug 22, 2009 at 6:45 AM
For the brake lights you need to get the turn/hazard switch checked out the bottom brake light circuit goes thru there.
Oil pressure-you need to check it with a mechanical gauge hook it up where the oil pressure sending unit if normal replace the oil pressure switch abnormal could mean oil pump or engine bearings.
Aug 22, 2009 at 7:21 AM
BNOBLE22
Thank you very much. Now that I think about it I accidentally hit the hazard light switch and my turn signals wouldn't work until I rattled it around. I am guessing that is what caused my brake lights to go out. Thanks for the oil pressure tip also.
Aug 22, 2009 at 8:09 AM
