1994 Pontiac Grand Am heating up
SHARONHALONEN122
Heater problem
1994 Pontiac Grand Am 200000 miles
When the temperture goes down to -32 the engine starts to over heat. Is there a heat sensor that controlls this?
Dec 19, 2007 at 1:07 AM
LEGITIMATE007
  • 5,121 POSTS
yes there is its called the (ECT) engine coolant temperature sensor. this is what tell the coputer how hot the coolant is so that it may turn the fans on or even retard the timing have it ohm tested for continuity. it can give the computer the wrong reading thus causing the computer not to turn the fans on.
Dec 27, 2007 at 5:59 AM
