1994 Pontiac Grand Am Egr valve
1994 PONTIAC GRAND AM
12,600 MILES • 6 CYL • FWD • AUTOMATIC
JAEF
  • 5 POSTS
i have noticed that there is moisture or condensation in the manifold on which my EGR valve is mounted. the moisture is also indide the EGR . Where is this moisture or condensation comming from?, and can it cause my EGR to malfunction? after changeing both oxygen sensor, and EGR valve, i have failed 2 emissions tests. can you help?
Apr 13, 2008 at 5:51 PM
2CARPRO JACK
  • 11,533 POSTS
The moisture can be caused by the fact that hot exhaust and cool intake come together at the EGR valve. What are you failing on the emissions test?
Apr 14, 2008 at 10:09 AM
JAEF
  • 5 POSTS
I 'm failing the NOx (oxides of nitrogan)
standard is 2.50 this time when I went it was 4.92
Apr 14, 2008 at 11:50 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a lack of EGR operation. Try pulling th evalve on manually with car at idle, should almost stall the engine, if it doesnt the passages are plugged and must be cleaned out. Is this an all electric valve or does it have a vacuum line
Apr 14, 2008 at 3:09 PM
JAEF
  • 5 POSTS
It is all electric
Apr 14, 2008 at 4:50 PM
2CARPRO JACK
  • 11,533 POSTS
No codes in the ECM?
Apr 15, 2008 at 4:06 PM
JAEF
  • 5 POSTS
I cant a scanner that goes back that far,and the port sems to be different than most(only has three places to plug pins into).tried to ground out proper spaces in plug to creat a"12" and get fault codes to come up ,but no luck.
Apr 15, 2008 at 6:27 PM
2CARPRO JACK
  • 11,533 POSTS
Might want to call around and find a shop that has a GM-1 connector and can scan it for you, this could greratly help in the search for the no EGR condition. Does the engine run at the proper temp? If not it wont turn on EGR, must be at running temp for the ECM to use the EGR
Apr 16, 2008 at 8:57 AM
JAEF
  • 5 POSTS
Had scan done,intake / Egr parts were carboned up pretty good, Egr was opening correctely but port(s)
wetre clogged. Had carbon cleaned out,hopefully car will now pass emissions, although service engine light did come on after driving 10 miles or so. any ideas?
Apr 19, 2008 at 3:09 PM
2CARPRO JACK
  • 11,533 POSTS
Need to have it scanned again (sorry). Might be something related to the carbon running through the engine when the EGR passages were cleaned.
Apr 20, 2008 at 7:30 AM
