1994 Pontiac Grand Am chirping sound when turning
99,500 MILES • 4 CYL • FWD • AUTOMATIC
SPOTBUYER
Recently I noticed that when I am beginning to drive forward (slow speed or even sitting still) two things occur: as I turn my steering wheel it is a sense of the tires "grabbing" and thudding as I turn the wheel, and is difficult to turn. Second, as I turn there is a "chirping" noise. This occurs while still as well as while driving (when I go to turn a corner, for example.) I have no leaks. Is this my power steering pump starting to fail? Thank you!
Jan 15, 2008 at 10:44 AM
BMRFIXIT
  • 19,053 POSTS
[quote:12adee3b1e="spotbuyer"]Steering problem
1994 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic 99500 miles
Recently I noticed that when I am beginning to drive forward (slow speed or even sitting still) two things occur: as I turn my steering wheel it is a sense of the tires "grabbing" and thudding as I turn the wheel, and is difficult to turn. Second, as I turn there is a "chirping" noise. This occurs while still as well as while driving (when I go to turn a corner, for example.) I have no leaks. Is this my power steering pump starting to fail? Thank you![/quote:12adee3b1e]
i would check power steering belt and replace it
good luck
Jan 15, 2008 at 11:00 AM
