1994 Pontiac Grand Am air shocks or not
1994 PONTIAC GRAND AM
125,000 MILES • 4 CYL • FWD • AUTOMATIC
FABLEFWAM
I have a class 2 tow hitch installed with a hydraulic lift attached that I use to haul a 3 wheeled handicap scooter. When the scooter is on the lift I only have 3 inches of clearance from hitch to ground. Will a set of air shocks lift this higher? The hitch is bolted to the frame.
Dec 3, 2007 at 9:35 AM
BLACKOP555
  • 10,386 POSTS
air shocks would if you set them pretty high, or a lift kit would help, and would be cheaper and easier in the end!
Dec 3, 2007 at 11:11 AM
