HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Drivetrain
Bearing Hub
Replace/Remove
1994 Pontiac Grand Am
PONTIAC MAN
MEMBER
1994 PONTIAC GRAND AM
6 CYL
FWD
AUTOMATIC
120,000 MILES
I am looking for direction on changing a front wheel beraing hub assembly
Monday, December 24th, 2007 AT 3:20 PM
SERVICE WRITER
MECHANIC
You are best to look at a manual and decide if you have the right tools for this before you get into it.
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Usually there are a series of 4 bolts that hold it to the spindle. There is a spec for tighting the axle nut that needs to be used.
SPONSORED LINKS
Tuesday, December 25th, 2007 AT 9:28 AM
Please
login
or
register
to post a reply.
Related Bearing Hub Replace/Remove Content
Noise After Changing Both Front Hub Bearing Assemblies
Changed Both Front Hub Bearing Assemblies And Now Makes A Growling Noise. Not Sure What To Look At Next. Did Not Do It Before They Were...
Asked by
Ryanshoe92
2004
PONTIAC GRAND AM
VIDEO
Wheel Bearing Hub Replacement
Instructional repair video
GUIDE
A bearing hub is used to allow the wheel to rotate while supporting the weight of the car and is mounted to the front or rear of the suspension system. The hub consists of a...
2004 Pontiac Grand Am Wheel Bearing/hub Assembly...
Hello. What Would Replacing The Wheel Bearing/hub Assembly Cost In Terms Of Labor. I Believe The Price Of $110 For The Part To Be Fair...
Asked by
cardinal1926
2004
PONTIAC GRAND AM
1999 Pontiac Grand Am Se
I Have A 1999 Pontiac Grand Am Se V6 3.4l 124,000 Miles And There Is A Constant Loud Humming Sound Coming From The Front End. My First...
Asked by
ptb127
1999
PONTIAC GRAND AM
Hub Bearings
I Have A 1999 Pontiac Grand Am Se, How Can You Tell If The Hub Bearings Need To Be Replaced And Are There Any Signs To Let You Know They...
Asked by
JESSEM
1 ANSWER
PONTIAC GRAND AM
1999 Pontiac Grand Am Wheel Bearing Noise?
When Driving Above 50mph There Is A Rattling Noise Coming From The Aft Right Side Of The Car. Could This Be A Wheel Bearing?
Asked by
k_johns23
1 ANSWER
1999
PONTIAC GRAND AM
VIEW MORE
SPONSORED LINKS
How to Replace Wheel Hub Assembly
CV Axle Replacement
Online car repair manuals
