1999 Pontiac Grand Am SE
1999 PONTIAC GRAND AM
PTB127
I have a 1999 Pontiac Grand AM SE V6 3.4L 124,000 Miles and there is a constant loud humming sound coming from the front end. My first thought was that it was a wheel bearing but both drivers and passengers side have been replaced already. When Im going about 40 mph, I go far over to the left and then turn the wheel slightly to the right and noise significantly lessens. I was in an accident about 10 mths ago and it was a passenger side hit. The rim was hit and had a black scuff that couldnt be cleaned so they changed the rim and I also reported that noise then too. On the final repair bill, it said they replaced the wheel bearing hub. I also replaced the axle on the drivers side along with the wheel bearing. Im pretty much at a loss on what to do with this problem. Do you think it is the axle on the passenger side?? Or do you think I purchased a shotty wheel bearing? Thank you for your imput!! Im very thankful for any suggestions!!
Pete
Jan 8, 2006 at 9:20 PM
PTB127
Can anyone help me out with this??
Jan 11, 2006 at 9:57 AM
BRYANDL72
if they got this wheel bearing at advanced could be bad also if axlle could have been put in wrong box from packing plant I had 1996 grand prix with 3.8 got axle for 3.1 just a coupls centimeters differnt but mean alot also have bought several bad wheel bearings
Oct 3, 2007 at 6:13 PM
