1994 Pontiac Grand Am White Dipstick Substance Fix
SAVEDMAN
I was checking my oil the other day and there was this white thick substance on the bottom portion of the dip stick. the oil was fine just that white stuff was on the tip, not all over. I've never seen that before in all my40+ years of driving can anyone help me on what it could be.
Thanks
Feb 18, 2006 at 11:01 PM
SCARBER
  • 6 POSTS
That white sticky substance is usually a moisture buildup in the oil system.
Feb 19, 2006 at 9:56 AM
MVANNESSJR
  • 223 POSTS
Would recommend doing an oil change and monitoring the oil for any changes.
Feb 20, 2006 at 6:23 PM
Suggested Repair
Change the oil and monitor it for any changes. The white sticky substance is usually moisture buildup in the oil system.
Conversation Summary
The owner of a 1994 Pontiac Grand Am found a white thick substance on the tip of the oil dipstick, while the oil itself looked fine. A reply said the white sticky substance is usually moisture buildup in the oil system. An expert recommended an oil change and monitoring the oil for any changes.
