1993 Pontiac Grand Am wont drive over 20 mph
KC4WWL
  • 1993 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 10,200 MILES
Car wont go over 20 mph what could be the problem we have changed the cat converter
Tuesday, March 31st, 2009 AT 8:09 PM
MMPRINCE4000
  • 8,548 POSTS
Check fuel pressure with mechanical gauge, then spark with spark tester. Have ign. Module tested at most autoparts stores. Another possibility is crank sensor, coolant temp sensor etc.
Do you have a check engine light on? If so retrieve codes and post them.
If you rule out the engine as problem, then transmission may be problem. It is best to have trans. Checked at shop, some are offering free diagnosis.
Wednesday, April 1st, 2009 AT 8:32 AM
