1993 Pontiac Grand Am Water Pump
95,800 MILES • 4 CYL • FWD • AUTOMATIC
AWITTE91
How do I replace the water pump on my 1993 Pontiac Grand Am Quad 4?
A step-by-step would be great!
Thanks for your help
Dec 2, 2009 at 1:51 PM
BMRFIXIT
  • 19,053 POSTS
Water pump is driven by timing chain idler sprocket and is mounted on rear of timing chain housing.
Disconnect negative battery cable.
Drain cooling system.
Disconnect oxygen sensor, and remove exhaust heat shields.
Remove exhaust manifold.
Disconnect outlet pipe from water pump cover, oil pan and transaxle.
Remove water pump nuts.
Remove water pump and cover assembly.
Remove water pump cover bolts.
Dec 2, 2009 at 9:58 PM
