Camshaft and timing chain marks and timing?
2.4L • 4 CYL • 2WD • AUTOMATIC
TJJEANES
set timing chain
Aug 27, 2014 at 4:15 AM
HMAC300
  • 48,601 POSTS
seepic for marks/location
Aug 27, 2014 at 11:48 PM
TJJEANES
Thanks
Aug 28, 2014 at 12:31 AM
JAMES WOOTEN
how to set timing marks for the timing chain?
Jun 14, 2021 at 3:29 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
here is the timing marks if that is what you were needing..
FOGUIE MCKINNIE
  • 51 POSTS
i have a 2000 pontiac grand am i need timing chain diagram
HMAC300
  • 48,601 POSTS
here ya go this is for a 3.4L as you didn't give engine size 2nd one with 2 cams is for a 2.4L next time give engine size..
2CP-ARCHIVES
  • 4,540 POSTS
how to set timing marks?
HMAC300
  • 48,601 POSTS
Here is the timing marks for the timing chain and camshafts. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
JOYCE ROBERSON
I replaced the water pump and afterward I set the timming wrong and broke the valves on two cylinder I had them replace and attempted to reset the timming but when I try to turn the engine over by hand it will only turn about a 180 degree turn
Jun 14, 2021 at 3:31 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Pay a close tension to the guides and tensioner recheck timing marks again
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_110.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_231.jpg
FLYBUZZ67
where do i find the timing marks on a 2.4 ltr dual overhead cam
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_timing_27.jpg
SHADOW52
i changed a blown head gasket. and i can't get the timing right. no compression. rocker arm cover say's quad 4, but it is not a quad 4. it is one of those quads that were only put in 2% of the vehicles, so i can't find a book or info on it.i need help to get it going. please! i'm a electrician if anyone needs answers on that subject.
Jun 14, 2021 at 3:32 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
This is the timing marks hope it's what you're looking for let me know
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_170.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_366.jpg
PRADOG
What are the specificationns for the timing chain marks on a 2 cam, engine?
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, Here is the timing alignment....
https://images.2carpros.com/forum/automotive_pictures/188069_92grndamtim4cyldohc_2.jpg
